luke130
Problem po zmianie karty graficznej
Po zmianie z GF9600GT na HD7770 i oczywiście usunięciu starych i zainstalowaniu nowych sterów mam problem z grami. A mianowicie żadna nie chce się uruchomić. Wywala komunikat o problemie z directx. Czy directx w win7 po zmianie grafy trzeba jakoś szczególnie potraktować czy może problem leży gdzie indziej?
Spróbuj tego, bo to już jest extremalna ;) metoda:
Guide (Nvidia)
1. Go to Add/Remove Programs
2. Uninstall all Nvidia associated software (May require several reboots)
3. Reboot the computer and log back into windows as normal
4. Go to folder options and select “show hidden files and folders”
The next part of the guide will remove all Nvidia files and folders from the computer.
5. Go to your C drive and remove any “Nvidia” folders if there is any
6. Double click the “Program Data” folder (Normally hidden) and remove all Nvidia folders
7. Go back to C and double click “Program Files” and remove all Nvidia folders
8. Go back to C and double click “Program Files (x86)” and remove all Nvidia folders
9. Go back to C and double click “Users”
10. Access the name of your windows profile and double click “AppData” (Normally hidden)
11. Check the “Local”, “LocalLow” and “Roaming” folders for any Nvidia folders and remove them.
12. Go back to “Users” and check the “Default” folder (Normally hidden)
13. Double click “AppData” (Normally hidden)
14. Check the “Local” and “Roaming” folders for any Nvidia folders and remove them.
The next part of the guide will remove registry entries left by the Nvidia drivers.
15. Close everything down and go back to your desktop
16. Click start, then type “regedit”.
17. Click “HKEY_CURRENT_USER” and extend the folder
18. Click “Software” and extend the folder
19. Remove all Nvidia Folders
20. Click “Wow6432Node” and extend the folder (Within the software folder)
21. Remove any Nvidia folders
22. Click “HKEY_LOCAL_MACHINE” and extend the folder
23. Click “SOFTWARE” and extend the folder
24. Remove all Nvidia Folders
25. Click “Wow6432Node” and extend the folder
26. Remove all Nvidia Folders
27. Click “HKEY_USERS” and extend the folder
28. Click “.DEFAULT” and extend the folder
29. Click “Software” and extend the folder
30. Remove all Nvidia folders
31. Click “S-1-5-18” and extend the folder
32. Click “Software” and extend the folder
33. Remove all Nvidia folders
34. Click “S-1-5-21-1632250243-966907716-928185508-1000” and extend the folder
35. Click “Software” and extend the folder
36. Remove all Nvidia Folders
37. Close down regedit and empty your recycle bin
38. Undo the folder options change to hide the hidden folders
39. Reboot
40. Install your AMD/Nvidia drivers and reboot
Z przykrością stwierdzam, że opisana metoda nie działa. :(
ps. Rozwiązaniem problemu okazało się odinstalowanie sterów i ponowna instalacja ale tym razem z konta administratora a nie jak poprzednio z jego uprawnieniami ale na koncie usera.
