kamilkusio
Baldur's Gate 3
Zgadzam się, podoba mi się ten dubbing. Można by przez takie narzędzia używać do spolszczenia/dubbingowania gier i wypuszczać jako mody.
Edytowane przez Reddzik
50h na zegarze, chyba ukończyłem 1 akt. Chyba, sprawdzam jeszcze miejscówki aby nawet 5 exp mi nie umknęło. 7 lvl aktualnie. Fantastyczna gra, choć ma swoje niedociągnięcia. Wątki miłosne można było sobie darować, straszna płycizna. Mam wrażenie, że dyskusje między kompanami są rzadsze i stoją na trochę niższym poziomie niż w OS2. Co do ekipy, Karlach i Astarion się wyróżniają.
A co za łatka 109mb do Baldura
zmiany
"Minthara lovers, your ship has come in. This hotfix takes care of a bug that blocked access to some of Minthara’s lines of dialogue, including some hot takes from your companions about your decision to date the ruthless Oath of Vengeance Paladin. If approval is high enough, your romance with Minthara will progress in Act 3. This unlocks several new dialogues allowing you to explore and deepen the relationship, and discover more details of Minthara's backstory. Alongside many lines of interactive dialogue, many more non-interactive voiced lines are available with Minthara as a romantic partner. Minthara isn't the only one who has new things to say though. Other companions in the party will comment on the relationship and may even find themselves on Minthara's bad side (there is no good side; we've looked really hard for it) should they have their own romantic entanglements with you. And Minthara won't watch silently if you stray from her side, whether your dalliance is with another member of the party, or [redacted]. We also have a number of fixes for just PS5 players. We’ve fixed graphical issues on HDR TVs, an issue in which game audio on PS5 stopped working, and a crash that would occur when opening the onscreen keyboard. Thank you for taking the time to send your reports to our support team, and for all the messages you’ve been sending us. Thank you for playing Baldur’s Gate 3!"
Dziwne pierwsza sytuacja że musiałem odczytać wcześniejszą grę bo quest czy raczej okno z nagrodą tak się zbugowało
I nijak nic nie mogę zrobić bo co do wyboru brakuje :E
Edytowane przez frog67
W dniu 4.09.2023 o 19:20, Reddzik napisał:
ta technologia rozwija sie w zastraszającym tempie, szukałem czegos o takiej jakosci ale jak szukałem to nie było a teraz juz jest, niesamowite.
  • Upvote 3
Dziwna sprawa z tym zabugowanym oknem z  nagrodą od wiedźmy, musiałem zaczynać calą walkę od początku :E
bo jak już wczytałem zapis w trakcie walki wcześniejszy to i tak zawsze pokazywało mi się zbugowane okno ! i nijak nic z tym nie zrobisz ani okna nie wyłączysz bo musisz wybrać nagrodę której nie ma :rotfl:
Najlepsze jest to, ze mozesz nagrac 120s gadania kogokolwiek: zony, brata, sąsiada, szefa, i na podstawie tego już stworzyć takie dialogi.
Netflix już dubbinguje przez AI ;)
Freeware - np. speechify.
Doszedlem w koncu do aktu 3ciego... ale ogromne jest to miasto - ale... lapek przestal wyrabiac i zrobilem przeskok z ultra presetu na medium/high. 🙃
To jest znany bug. Rozwiązania są dwa ;)
quick save i quick load na tym oknie, po wczytaniu załaduje Ci się poprawnie
Włączyć pada i sterowanie kontrolera też powoduje przeładowanie interface i naprawia sytuację
A tymczasem u mnie na finiszu I aktu (prawie 28h)  kolejny bug w Baldurze może i pierdoła ale wkurza
myślałem że jak wskoczy II akt to się naprawi i kiszka
:E
Karlach przecież nie jesteś brzydka że aż ci ikonę zabrali
Może się wstydzi :E U mnie jak narazie po 33 godzinach, żadnych znaczących błędów. Raz gra się wywaliła do pulpitu i raz nie mogłem zejść ze skrzyni, ale po wczytaniu save'a już było ok (nie wlazłem na nią w sensie :D)
@Pavel87
Nie dało się nawet zeskoczyć (używając skoku)?
Jakoś mi trudno w to uwierzyć, przecież nawet da się skakać w przepaść i zginąć.
@Kabor
Nie, jak próbowałem zeskoczyć to nie podświetlało mi żadnego możliwego miejsca do zeskoku :E
nastepnym razem polecam rozwalic skrzynie :E
3 godziny temu, Pavel87 napisał:
@offensive
Widzisz, na to nie wpadłem :D
Często te najprostsze rozwiązania są najlepsze
Ja pół pierwszego aktu się szlajałem przynajmniej z 5 beczkami oleju pod pachą :E   ... i było warto 💥
szczególnie jak widzisz że coś się kroi i będzie dym no to na dzień dobry zostawiasz beczki i do widzenia !
możesz też nosić 3 skrzynki i ustawić je sobie przed walką, wtedy masz high ground advantage od kopa ;)
z innych dzikich tematów to np. goście rzuceni butelką wody dostają większe od elektrycznych/lodu (woda trafiona lodem zamarza i robi się trudny teren), podróże między krainami leczą drużynę, można podzielić u sklepikarza kasą na mniejsze porcje i wtedy dużo łatwiej je ukraść ;)
Edytowane przez Alyjen
To niesamowite jak bardzo "czynniki zewnętrzne, środowiskowe" i  oczywiście "myślenie" mogą wpłynąć na przebieg walki :) Z wodą już próbowałem, ustawiałem już beczki z prochem wokół wrogo nastawionych osobników, dzięki niektórym z tego typu akcji, walki zamykały mi się już w pierwszej turze. Super, że gra daje tyle różnych możliwości. Co Larian musi mieć w głowie, że oni to wszystko tak fajnie wymyślili :D
Wczoraj walczyłem z jakimś czarownikiem, który stał na podwyższeniu, rzuciłem obok niego "kwiat sussur", przez co nie mógł czarować, spaliłem też drabinę żeby nie mógł do mnie zejść. Oczywiście zeskoczył (:E) , co prawda nie zginął, ale dobicie go było już tylko formalnością.
  • Like 2
Jest fajny build dla Wojownika/Barbara w którym dajesz halabardę, wartownika i mistrzostwo w drzewcowych i jak tylko ktoś przechodzi w zasięgu ataku, który dzięki halabardzie jest większy to możesz go pacnąć, a dzięki wartownikowi trafiony staje w miejscu i nie może kontynuować ataku ;) zrobisz coś takiego np. Karlach i masz rasowego wykidało
W dniu 6.09.2023 o 14:31, Dudzio napisał:
A jakie to narzędzie?
masz podane przeciez w tytule filmu
Skończyłem gierkę ponad 75h jedna z lepszych gier ostatnich  10 lat. Super gra ocena 10/10 jak  byk
Robiliście w pierwszym akcie Podmrok i Górską Przełęcz? Czytałem, że jest taka możliwość żeby przejść te dwie lokacje w ramach pierwszego aktu (do jakiegoś kulminacyjnego momentu). Ja już mogę iść do wieży w Podmroku, ale zastanawiam się czy nie ogarnąć jeszcze w jakimś stopniu górskiej przełęczy, nie wiem po prostu czy jest sens
Ponoć się da, ale ja tego nie zrobiłem i ponoć straciłem kawałem zawartości w grze, a gra kazała wybrać drogę, i myślałem, że wybierając jedną nie można zwiedzić drugiej.... byłem w błędzie.
  • Popularne aktualnie
    • Syf jak syf, ale faktem jest, że nawet renomowane/drogie masła potrafią być nadmiernie zanieczyszczone olejami mineralnymi MOSZ/MOAH, czy to w trakcie produkcji przedostawać się do żywności z olejów smarowych maszyn czy też z opakowań aluminiowych pokrytych woskiem w testach wyszło, że czym bliżej końca terminu ważności takie masła miały więcej tych substancji.
    • Polecam obejrzeć ten webinar, co prawda jest z 2021 roku ale nadal aktualny moim zdaniem. Prowadzący rekomenduje: F-Secure. Bitdefendera, Kaspersky i Eseta. Bardzo ciekawy webinar.
    • Podjąłem pracę nad projektem AI, przy którym mój gamingowy laptop z 64GB RAM i RTX 3070 z 8GB VRAM przestał wystarczać. Jako że pracuję zdalnie, to będzie to komputer który będę miał w domu i po pracy będę mógł na nim grać Ale jedziemy z tematem, najpierw moja propozycja, potem uzasadnie i wątpliwości z którymi tu przychodzę: CPU 14900KF lub Ryzen 7950X3D Mobo: ASUS ROG STRIX z chipsetem odpowiednio Z790 lub X670E GPU: ASUS GeForce RTX 4090 TUF Gaming OC RAM: Corsair Vengeance 192GB [4x48GB 5200MHz DDR5 CL38 DIMM] SSD: Crucial P3 Plus M.2 PCI-e NVMe 4TB PSU: be quiet! Dark Power 13 1000W Obudowa: Fractal Design Define 7 Black TG Light Tint ATX Chłodzenie CPU: be quiet! Silent Loop 2 360mm 3x120mm A teraz moje wątpliwości, które chcę skonsultować: Po pierwsze PSU. Zawsze brałem be quiet! i byłem zadowolony z tych zasilaczy. Zero awarii, ciche. Wchodzę w komentarze zachwalanego Dark Power 13 1000W a tam piszą, że często się trafia terkoczący wiatrak. Czy ciągle jest z tym problem? Ten zasilacz jest już rok na rynku. A to i tak dobrze, bo przy Dark Power Pro zarówno dla 1300W jak i 1600W piszą o paleniu się bezpieczników i wywalaniu korków! Takie komentarze są na Komputroniku, X-Komie i Morele.net. Co to za jaja? W ogóle, to ludzie w tych komentarza pisali, że zostało im wymienione na nowe i nowy też walnął. Więc albo wadliwa seria albo to nie w zasilaczu był problem. Ale w takim razie dlaczego przy innych zasilaczach taki problemów nie zgłaszają? Choćby przy serii Straight Power? Akurat Straight Power 12 o mocy 1200W miał mój kolega i mu padł, ale to był jakiś cały zestaw zamawiany z Niemiec. Tak w ogóle czy 1000W wystarczy? nVidia rekomendacje minimum 850W dla RTX4090. Patrzyłem na testy całych zestawów z RTX4090, to przy obciążeniu biorą tak do 600W (Intel 13900K). Natomiast kalkulator na stronie be quiet! mi zalecił brać minimum 1200W do takiego zestawu pisząc, że przy 1000W będzie load 94%. CPU - Intel jest minimalnie szybszy, ale jak patrzę po zużyciu energii to AMD przy pełnym obciążeniu bierze ~200W mniej. Myślę, że mogę to odczuć w rachunkach za prąd, ale ten prąd zarabia na siebie. Ponadto AMD obsługuje AVX-512, które być może będę chciał wykorzystać. No i wiadomo, zostaje spore pole do upgrade na przyszłość. Mobo: Wybrałem ASUS bo w poprzednich kompach miałem Asusy i byłem z nich zadowolony. Ale chętnie poznam opinie. Np. czy warto dopłacać do Maximus jeśli nie zamierzam podkręcać? GPU: RTX 4090, tylko pytanie jaki? Patrzyłem w benchmarki, niewiele się różnią. Wybrałem tego Asusa bo najcichszy. Tak czy siak RTX 4090 w zasadzie nie ma konkurencji. Przy AI najważniejszy jest VRAM, bo na wolniejszym policzy wolniej, ale jak braknie VRAM to w ogóle nie policzy. Najlepsze byłoby coś z 48 albo jeszcze więcej RAM, ale takie karty przekraczają budżet całego kompa i nie nadają się do grania  aha i AMD odpada, bo są problemy ze zgodnością bibliotek na których pracuję, RAM: więcej się nie da, a te kości bo to jedyny zestaw jaki znalazłem   mam nadzieję, że wystarczy, nie ma opcji. Ale tu mnie jeszcze ratuje dostęp do maszyny, która ma 1,5TB RAM ale jest bez GPU, SSD: mam go w laptopie i się sprawdza, Obudowa: miałem Fractal Design Define 4 i byłem z niej zadowolony więc wybrałem następcę, ale jestem otwarty na propozycje. Chłodzenie CPU - tu jestem zielony, to co wpisałem ktoś polecił tu na forum w innym poście W ogóle gdzie teraz najlepiej zamawiać zestaw, który mi zmontują i przetestują przed sprzedażą? X-Kom? Komputronik? Morele? Coś innego? Już miałem raz sytuację, że brałem nowego kompa, składanego w konfiguratorze i po dwóch dniach musiałem go reklamować, bo działał bardzo niestabilnie. Tam montaż był gratis, który polegał na tym, że po prostu złożyli i włączyli, włączył się, więc uznali, że ok. Na szczęście nie musiałem sam szukać który element jest wadliwy, tylko przyjęli całego kompa i sami to sprawdzili. Niemniej wolałbym uniknąć tych nerwów i przestoju
    • @PiPoLiNiO masz pełną rację. Jestem tego samego zdania co Ty. ... natomiast liczyłem na to, że Sylwester też dojdzie do takiego wniosku. 😉 ps. no może poza tym, że mnie by jakoś 27" obleciało ... ale 4K musi być, szczególnie na OLED 😉
