ziomolo
Forumowicze
  • Liczba zawartości
    5
  • Rejestracja
  • Ostatnia wizyta
Odpowiedzi dodane przez ziomolo
  1. Jak wiesz lepiej to sie nie pytaj !!
    heheeh
    a teraz ?? ;p
    Statistics -- ADSL
    Mode:     G.DMT
    Type:     Interleave
    Line Coding:     Trellis On
    Status:     No Defect
    Link Power State:     L0
                        Downstream     Upstream
    SNR Margin (dB):      29.5      29.0
    Attenuation (dB):     25.0      11.0
    Output Power (dBm):   19.8      12.1
    Attainable Rate (Kbps):8864     1184
    Rate (Kbps):           2496      320
    K (number of bytes in DMT frame):          79      11
    R (number of check bytes in RS code word): 16      8
    S (RS code word size in DMT frame):         2      8
    D (interleaver depth):                     16      2
    Delay (msec):                               8      4
  2. Hej, witam, takie mam parametry na routerze (czy potrzeba jeszcze coś?)
    Statistics -- ADSL
    Mode: ADSL2+
    Type: Interleave
    Status: No Defect
    Downstream Upstream
    SNR Margin (dB): 26.4 28.5
    Attenuation (dB): 28.5 10.1
    Output Power (dBm): 0.0 12.4
    Attainable Rate (Kbps): 9976 388
    Rate (Kbps): 2492 317
    MSGc (number of bytes in overhead channel message): 59 72
    B (number of bytes in Mux Data Frame): 38 9
    M (number of Mux Data Frames in FEC Data Frame): 1 16
    T (Mux Data Frames over sync bytes): 2 1
    R (number of check bytes in FEC Data Frame): 16 16
    S (ratio of FEC over PMD Data Frame length): 0.4944 14.5155
    L (number of bits in PMD Data Frame): 890 97
    D (interleaver depth): 64 1
    Delay (msec): 7 3
    mam netie 2Mb/s usilnie mi oferują zwiększenie prędkości. jaką mógłbym mieć max prędkość??
