limak122
Forumowicze
  • Liczba zawartości
    714
  • Rejestracja
  • Ostatnia wizyta
Odpowiedzi dodane przez limak122
  1. DLA WSZYSTKICH KTÓRYM REDUX NIE DZIAŁA PO UPDATE
    KYLO REN IS HANS SON, KYLO KILLS HAN SOLO KYLO REN IS HANS SON, KYLO KILLS HAN SOLO
    After doing some googling on how to get this mod working, I finally got this mod to work for me with the Biker Update.
    1. Reinstall your GTAV so you get a clean installation.
    2. Follow the appropriate steps to install GTAV Redux including the Day 1 patch.
    3. Go to your GTAV Directory/update/x64/dlcpacks/ copy the mpbiker folder and put that in to your mods folder.
    4. Update your GTAV Script hook, the latest release was Oct 5, 2016 for version 1.0.877.1. You just have to copy and paste the dinput8.dll and ScriptHookV.dll into your main GTAV directory.
    5. You need to download this gameconfig patch which contains an updated gameconfig.xml which you use OpenIV to replace the xml file located at: GTAV / mods / update / update.rpf / common / data. Ofcourse back up your gameconfig.xml thats in there and then press edit mode and copy / paste over the modified gameconfig.xml
    The file is located here: https://www.gta5-mods.com/misc/gameconfig-for-patch-1-0-757-2-update-at-each-r-update
    I did not have to delete x64a or anything like that. I just did these exact steps and I am able to play GTA V Redux finally!
    Thanks to thePain from the gtaVRedux comments section for pointing out the gameconfig.xml update and Killer Penguino in this discussion thread for pointing out key steps in order to fix the crashes :D
  2. Działają jeszcze serwery TP (Team Play?) Gdzie mapa była podzielona na strefy, których nie można było opuszczać po upłynięciu określonego czasu? Uniemożliwiało to wykonanie szybkiego rashu na spawny i wymuszało grę zespołową. Ludzie byli ogarnięci i na prawdę fajnie się grało.
    edit Aha grałem na nich w 2008roku gdzieś w CS:Source
  3. Nie słuchaj się tych nerdów. Wujek Limak ci napisze jak znaleźć dziewcze. Proces to długi i żmudny, a najważniejsza w nim jest wiara w siebie. Jako, że wyrwałem 4 laski (słownie cztery) odkąd pamiętam, myślę,że mogę się udzielić w tym temacie. Będąc młodym Limakiem zastanaiwialem się jak to jest poczuć zapach młodej cipciuni, to skłoniło mnie do zadania sobie takich samych pytań jak ty. Pierwszą i chyba naważniejszą rzeczą, którą śmiało mogę opisać jako katalizator mojego first time jest zaprzestanie udzielania się na labie. JEst to rzecz ważna albowiem daje ci mnóstwo dodatkowego czasu na przygotowywanie się do wyrwania laseczki. Kolejnym ważnym korkiem jest znalezienie sobie hobby które w przyszłości sprawią, że będziesz bardziej pewny siebie. Siłka musisz znaleźć kolegę koksa, który ma siłkę i zacząć chodzić. Jeżeli co bardzo prawdopodobne nie masz kolegę koksa, załatw sobie ławkę lub kup ją na allegro. Wraz z paroma ciężarkami i pomocą z internetu po roku dwóch może trzech lat dojedziesz do perfekcji i z determinacją będziesz dawał upust swojej energi. Polecam dodatkowo różnego rodzaju specyfiki, czyli odżywki (pubudzacz, nawadniacz, białko, masa , witaminy). Następna rzecz Charakter. Ćwicząc już na siłowni widzisz, że pewne działania przynoszą rezultaty. Na początku potrafiłeś podnieść 30 kg 10 razy teraz potrafisz 35kg. CZujesz się silniejszy, wiesz, że dążenie do celu przynosi rezultaty, które możesz policzyć, poczuć , użyć. Charater nie jest tworzywem, które łatwo uformować. Jeżeli nie masz Ojca, który silną ręką karcił cię za to, że żyjesz twój charakter może być niewystarczający by wyrwać laseczkę (a w przyszłość panować nad nią). TAk więc, musisz dostać pare razy po ryju, żeby zbuntować się i skupić tylko na sobie i swojej sile, którą posiadasz głęboko w sercu. Złóść , bezsilność , które poprowadzą cię prosto do lekkomyślności nauczą cię pokory i cierpliwości. Upust lekkomyślności czy jak to tam ten stan nazwać najlepiej dać w ciekawości. Czyli spróbuj podnieść poziom serotominy, pal zioło, pij alko i pal szlugi.
    Gwarancja 100% po takim cyklu jak ten wyżej nie będziesz już zadawał takich głupich pytań jak wyrwać dziewczyne.
  4. Po roku od zakupienia postanowiłem zrobić format c: :) 69 procesów działających w tle daje się we znaki.
    Jestem w tym momencie na poziomie wgrywania sterowników. Oczywiście nie mogę znaleźć płyty dołączanej do laptopa więc wszystko szukam po necie. Nie mogę znaleźć sterów do klawiatury aby móc korzystać z skrótu "Fn" aby podgłośnić albo podświetlić ekran. Jak komuś się chce mógłby sprawdzić na płycie ze sterownikami czy istnieją jakieś do klawiatury :)
  5. Stało się. Zostałem naocznym świadkiem. Będąc nad morzem między 10 sierpnia między 00.00, a 2.00 w nocy widziałem na niebie niezidentyfikowany obiekt latający. O astronomii mam dość dobre pojęcie, potrafię odróżnić obiekty na niebie od siebie. Takie rzeczy jak samolot, satelity, gwiazdy, komety i spalające się meteoryty. Nigdy za bardzo nie liczyłem na to, że uda mi się zobaczyć coś tak niezwykłego. Leżąc na plaży i wpatrując się w niebo zauważyłem świecący na pomarańczowo obiekt, który pojawił się znikąd, wykonał 5 ruchów na niebie i odleciał. Wyglądało to mniej więcej Tak i odleciało. Niezwykły w tym wszystkim jest fakt, że obiekt ten wykonał te ruchy w nieosiągalny dla samolotów sposób. Żaden znany mi z Discovery pojazd latający nie byłby wstanie wykonać takich manewrów. Warto też wspomnieć o tym co mogło zainteresować ten obiekt. Przy plaży były mocne światła skierowane ku niebu. Wyglądało to tak jakby obiekt zainteresował się tymi światłami, zobaczył co to jest i odleciał.
    Chciałem się tym tylko podzielić na forum, jak to robi każdy, kto zobaczy coś w tym stylu.
    Pozdrawiam.
  6. Gdzieś słyszałam o gościu, który zawsze ubierał się od prawej strony, tzn. najpierw prawy rękaw, potem lewy, najpierw prawy but, potem lewy, etc. Jak się pomylił, to musiał zdjąć i założyć jeszcze raz, bo go swędziało. :E
    A co do mnie: nie otwieram ust kiedy maluję rzęsy :P:E
    A to bardzo nieekologiczne jest, wiesz? :Up_to_s:
    Chyba nieekonomiczne :)
    * utwory w folderach i w itunes musza byc odpowiednio posegregowane tzn folder (nazwa zespolu) -> folder nazwa zespolu_-_nazwa albumu_-_rok produkcji albumu -> nazwa zespolu_-_tytul piosenki.mp3 + okladka z albumu. jesli tego nie zrobie, nie wsadze tego do itunes -> nie wsadze tego do ipoda -> nie bede tego sluchal.
    * bilety do multikina rezerwuje zawsze wczesniej, na najwieksza sale, w ostatnim rzedzie jak najbardziej na srodku. bilet na ostatnia chwile byle gdzie nie wchodzi w gre. co innego jesli wybieram sie do kin offowych.
    * kupujac cokolwiek musze wiedziec, ze jest to gorna polka. wole zakupic jedne spodnie wranglera za 300 zl niz 3 pary jeansow z h&m po 100 zl. tak samo ze sprzetem elektronicznym, odzieza sportowa, outwearem.
    * za zadne skarby swiata nie zjem cebuli (wyjatki: pierogi ruskie, sznycle - ale tylko wtedy gdy jest drobno posiekana i smazona). nie ma takiej opcji, zebym zjadl kawalek surowej cebuli < -- byla smieszna sytuacja na rodzinnym objedzie u dziewczyny.
    * jestem chory na hematofobie. widzac krew, slyszac rozmowe o krwi, zlamaniach kosci, operacjach, wyjatkowo nieprzyjemnych chorobach robi mi sie slabo. w ten sposob zaliczylem juz kilka omdlen.
    to dla ciebie.
    Ja jak śpię to naprzeciwko mam komputer i fotel, zawsze zasłaniam fotelem monitor bo mi się wydaje, że jakieś promieniowanie od niego bije, nawet jak jest wyłączony. Jak fotel odsłania monitor to nie zasnę. Ale co mnie zdziwiło, to jak przeniosłem komputer do innego pokoju na czas malowania, to nadal fotel musiałem ustawiać w pozycji zasłaniającej monitor, mimo że go tam przecież nie było :hmm:
    To już podchodzi pod leczenie.
    Właśnie przed chwilą zdałam sobie sprawę z tego, że jak wycieram nos to chusteczkę później składam w idealną kosteczkę. I wycieram nos jedną reką (zawsze lewą, prawą nie umiem :E )
    Też tak robię, ale nie wycieram nosa...
    Ja mam coś nie teges że co jakieś 2 godziny myję ręce i koniecznie rano prysznic, bo inaczej czuje się jakiś taki... brudny :E I muszę mieć codziennie świeżą koszulkę/koszulę :E
    Też tak mam- jesteś spoko.
    Hehehe to ja sie przyznam ze mam cos podobnego. Idac i mijajac np. jakis niebezpieczny pret wystajacy z ziemii + jakies strome, kamienne, mocno zniszczone schody wyobrazam sobie alternatywny ciag wydarzen, czyli co by sie stalo gdybym na to upadl itp. itd. - Chore xD. Najlepsze, ze takie nagle wyobrazenia mam czasami takze przy rzeczach typu klamka od drzwi + sliska podloga - ojjj wtedy to wyobraznia idzie w ruch xD. Dodam, ze te cale wyobrazenia sa ukazane w sposob hmmm naturalistyczny - bardzo szczegolowy i... bolesny (zawsze az mnie ciary przechodza) :). Ale musze powiedziec, ze to sie czasami przydaje bo po takiej wizualizacji do niektorych rzeczy podchodze z wieksza ostroznoscia (co nieraz uchronilo mnie przed bolem :D).
    Czizys nigdy sie z nikim takimi rzeczami nie dzielilem, Pozdro ;)
    Ja tak mam gdy jestem gdzieś i zaczyna mi się nudzić. Tylko ja najczęściej wyobrażam sobie jakąś złożoną extremalną sytuację i myślę co musiałbym zrobić aby z niej wyjść. Najczęściej jest to szkoła i atak terrorystyczny. Zawsze wygrywam z terrorystami :) Zabijam wszystkich w jakiś heroiczny sposób i z raną postrzałową całuję się z nauczycielką od matmy.
  7. Witam.
    Zwracam się do was o pomoc w wyborze gitary dla siostry. Kompletnie się na gitarach nie znam i nie chciałbym kupić jej jakiegoś bubla na allegro. Na początek myślę, że wystarczy jej gitara za max 200zł. Siostra ma 10lat i ma zamiar uczyć się grać satanistyczne pieśni w swojej sekcie. No dobra, żartowałem, będzie uczyła się grać jakieś religijne piosenki z siostrami zakonnymi. smilies/wink.gif
  8. Witam, mam małe pytanie do expertów ;p Jak nazywa się rodzaj muzyki w której kilku przeważnie czarnych kolesi wydaje z siebie rytmiczne dźwięki, najczęściej strzelając do rytmu palcami ? Tacy kolesie są w np. Rockym Balboa (stoją przy zapalonym śmietniku i sobie śpiewają).
    Miło byłoby gdyby jeszcze ktoś zapodał nazwę jakiejś grupy :)
  9. bla bla bla
    Mam takie pytanie. Grałeś może w podrywaczach? Pamiętam kiedyś u kolegi upaleni oglądaliśmy jakiś odcinek "na łacha" i wydaje mi się , że tam był koleś co identycznie wyglądał, albo to byłeś ty. Na serio się pytam.
    Napisałem na PW
  10. 2+2
    Geez... dawno to bylo. Zaraz sobie przypomne to moze bede wiedzial, chociaz to chyba jednak nie ta godzina...
    a my na chemi w LO 3 lata temu wyrzuciliśmy okno przez okno :heu:
    Sorry. Nie mam pajecia jak to zrobic. Znaczy cos mi tam swita, ale nie chce wprowadzac w blad jezeli nie jestem pewny.
    Zajrzyj do książki i powtórz materiał.
    :rotfl:
