meo_pl
AMD 2400g i BSOD podczas gry - atikmpag.sys
Witam kolegów.
Piszę w sprawie problemów z procesorem a raczej kartą graficzną. Po pewnym czasie załączając jakąkolwiek grę odnotuje BSOD.
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (http://www.osr.com)
Online Crash Dump Analysis Service
See http://www.osronline.com for more information
Windows 8 Kernel Version 16299 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 16299.15.amd64fre.rs3_release.170928-1534
Machine Name:
Kernel base = 0xfffff802`a5808000 PsLoadedModuleList = 0xfffff802`a5b6f130
Debug session time: Tue Mar 20 16:46:17.815 2018 (UTC - 4:00)
System Uptime: 0 days 1:42:55.488
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffff9d0bc20e5010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff80904d5f814, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc0000001, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000003, Optional internal context dependent data.
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
FAULTING_IP:
atikmpag+f814
fffff809`04d5f814 48895c2408 mov qword ptr [rsp+8],rbx
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
ffff968d`cbacaa18 fffff809`039cce10 : 00000000`00000116 ffff9d0b`c20e5010 fffff809`04d5f814 ffffffff`c0000001 : nt!KeBugCheckEx
ffff968d`cbacaa20 fffff809`03997059 : fffff809`04d5f814 ffff9d0b`d3aab010 ffff9d0b`d3aab0e0 00000000`00000000 : dxgkrnl!TdrBugcheckOnTimeout+0xec
ffff968d`cbacaa60 fffff809`03997b75 : ffff9d0b`c20e0110 00000000`10000000 ffff9d0b`d3aab010 00000000`10000000 : dxgkrnl!DXGADAPTER::PrepareToReset+0x159
ffff968d`cbacaab0 fffff809`039cc5a5 : 00000000`00000100 00000000`00000300 ffff9d0b`d67cbe90 ffff9d0b`d4dcf040 : dxgkrnl!DXGADAPTER::Reset+0x229
ffff968d`cbacab20 fffff809`039cc6f7 : 00000000`00000300 ffff9d0b`d7a0f910 ffff9d0b`c02cea80 fffff802`a58b7920 : dxgkrnl!TdrResetFromTimeout+0x15
ffff968d`cbacab50 fffff802`a58434d5 : ffff9d0b`d4dcf040 fffff809`039cc6d0 ffff9d0b`c02cea80 00000000`00003c4e : dxgkrnl!TdrResetFromTimeoutWorkItem+0x27
ffff968d`cbacab80 fffff802`a591ec07 : ffff9d0b`d4dcf040 00000000`00000080 ffff9d0b`c02c7040 ffff9d0b`d4dcf040 : nt!ExpWorkerThread+0xf5
ffff968d`cbacac10 fffff802`a5984cc6 : fffff802`a4b51180 ffff9d0b`d4dcf040 fffff802`a591ebc0 ff565654`ff565654 : nt!PspSystemThreadStartup+0x47
ffff968d`cbacac60 00000000`00000000 : ffff968d`cbacb000 ffff968d`cbac5000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
atikmpag+f814
SYMBOL_NAME: atikmpag+f814
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME: atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 5a79448c
FAILURE_BUCKET_ID: X64_0x116_IMAGE_atikmpag.sys
Followup: MachineOwner
Przeinstalowanie sterowników nie pomogło. Ręcznie dodanie driverów również nie odniosło skutku. Macie jakieś pomysły?
Będę bardzo wdzięczny z wszelaka pomoc z góry wielkie dzięki.
Prościej o pomysły gdy dysponuje się czymś więcej niż 2400g zawieszonym w powietrzu...
cpu: 2400G Ryzen
mobo: msi b350m bazooka
mem: 2x8GB ddr4 goodram 3000mhz
ssd: mx200 500gb
psu: corsair c650m
Radeon Software Version
17.7
Driver Packaging Version
17.40.3701-180206a-324287C-ATI
Windowes 10 64bit home - 1709
Najpierw spróbuj wyłączyć XMP - tak, by ram pracował na parametrach JEDEC (zwykle 2133 albo 2400).
Masz najnowszy bios na płycie?
W biosie zmieniłem na standardowo pamięci oraz zmieniłem w chrome wykorzystywanie akceleracji graficznej na brak.
BIOS mam ze stycznia tego roku.
Teraz wypluł mi taki BSOD:
Machine Name:
Kernel base = 0xfffff801`fd899000 PsLoadedModuleList = 0xfffff801`fdc00130
Debug session time: Sun Mar 25 16:27:07.010 2018 (UTC - 4:00)
System Uptime: 0 days 1:17:58.685
KMODE_EXCEPTION_NOT_HANDLED (1e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff801fd9534be, The address that the exception occurred at
Arg3: 0000000000000000, Parameter 0 of the exception
Arg4: ffffffffffffffff, Parameter 1 of the exception
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
FAULTING_IP:
nt!KiSwapThread+1ee
fffff801`fd9534be c3 ret
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPagedPoolEnd
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
BUGCHECK_STR: 0x1e_c0000005
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: csrss.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from fffff801fd93d6c9 to fffff801fda0e510
CONTEXT: 0f20c0f641000005 -- (.cxr 0xf20c0f641000005)
Unable to read context, Win32 error 0n30
STACK_TEXT:
ffffce84`f2d8dc98 fffff801`fd93d6c9 : 00000000`0000001e ffffffff`c0000005 fffff801`fd9534be 00000000`00000000 : nt!KeBugCheckEx
ffffce84`f2d8dca0 fffff801`fda21602 : 00000000`00000000 fffff801`fd954f74 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x239
ffffce84`f2d8e350 fffff801`fda1d110 : 00000000`00000000 00000000`00000000 00000000`00000000 ffffce84`f2d8e5d8 : nt!KiExceptionDispatch+0xc2
ffffce84`f2d8e530 fffff801`fd9534be : ff66f801`fd952dde 00660000`00000001 ff66f801`fd8e45dd ffff858a`19b09b98 : nt!KiGeneralProtectionFault+0x3d0
ffffce84`f2d8e6c8 ff66f801`fd952dde : 00660000`00000001 ff66f801`fd8e45dd ffff858a`19b09b98 ff66858a`19b37080 : nt!KiSwapThread+0x1ee
ffffce84`f2d8e6d0 00660000`00000001 : ff66f801`fd8e45dd ffff858a`19b09b98 ff66858a`19b37080 ff66858a`19b37080 : 0xff66f801`fd952dde
ffffce84`f2d8e6d8 ff66f801`fd8e45dd : ffff858a`19b09b98 ff66858a`19b37080 ff66858a`19b37080 ff66f801`fd8e7de9 : 0x660000`00000001
ffffce84`f2d8e6e0 ffff858a`19b09b98 : ff66858a`19b37080 ff66858a`19b37080 ff66f801`fd8e7de9 ffff858a`00000000 : 0xff66f801`fd8e45dd
ffffce84`f2d8e6e8 ff66858a`19b37080 : ff66858a`19b37080 ff66f801`fd8e7de9 ffff858a`00000000 ffff858a`19364330 : 0xffff858a`19b09b98
ffffce84`f2d8e6f0 ff66858a`19b37080 : ff66f801`fd8e7de9 ffff858a`00000000 ffff858a`19364330 fffff74a`c00e8650 : 0xff66858a`19b37080
ffffce84`f2d8e6f8 ff66f801`fd8e7de9 : ffff858a`00000000 ffff858a`19364330 fffff74a`c00e8650 00000000`00000000 : 0xff66858a`19b37080
ffffce84`f2d8e700 ffff858a`00000000 : ffff858a`19364330 fffff74a`c00e8650 00000000`00000000 ffffce84`f5829900 : 0xff66f801`fd8e7de9
ffffce84`f2d8e708 ffff858a`19364330 : fffff74a`c00e8650 00000000`00000000 ffffce84`f5829900 ffff858a`0690d700 : 0xffff858a`00000000
ffffce84`f2d8e710 fffff74a`c00e8650 : 00000000`00000000 ffffce84`f5829900 ffff858a`0690d700 00000000`0000000b : 0xffff858a`19364330
ffffce84`f2d8e718 00000000`00000000 : ffffce84`f5829900 ffff858a`0690d700 00000000`0000000b ffff858a`19b2e011 : 0xfffff74a`c00e8650
FOLLOWUP_IP:
nt!KiSwapThread+1ee
SYMBOL_STACK_INDEX: 4
SYMBOL_NAME: nt!KiSwapThread+1ee
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5a979177
STACK_COMMAND: .cxr 0xf20c0f641000005 ; kb
FAILURE_BUCKET_ID: X64_0x1e_c0000005_nt!KiSwapThread+1ee
Co dziwne, od jakiegoś czasu zmagam się z podobnym BSODem, atikmdag.sys, a mam r5 1600, kiepsko by było gdyby to karta padała :E
Siemka, mam ten sam problem.
ryzen2400g
ab350m-gigabyte
2x4gb gskill ripjaws 3200mhz cl16
ssd 256gb
vega 11
Bios zaktualizowany z marca tego roku.
Od dnia zakupu do dnia dzis borykam sie z tymi blue screenami... atisys, kernel check itd Freezy w grach 3d i czasem 2d. W sumie nie czuje komfortu pracy jak na Win7.
Pewnie jak bym dolozyl jakiegos GTX'a to byc moze problem by ustal, a Vega 11 wylaczylbym w biosie.
Witam . Czy rozwiązałeś ten problem ?
Dolaczam sie, BSOD pojawiaja sie co jakis czas, tak srednio raz w tygodniu. Chyba to normalka az do wyscia nowego biosa. Mam Arocka x370 gaming x. Kilka dni temu byl update windows 10 i od tego czasu przy zmianie rozdzielczosci np przy ogladaniu filmow w fullscreen (zmiana z 2k na full HD) obraz robi sie "krzacasty" z fioletowym/niebieskim za zabarwieniem. Zmiana rodzielczosci pomaga. Co to moze byc? Przeinstalowalem sterowniki AMD od Asrocka ale nic nie dalo.
Swego czasu oglądałem recenzję na temat APU AMD na gamer nexusie. Polecali by instalować windowsa na świeżo, w najnowszej kompilacji, dzięki czemu część pewnych bdsoów znikała. + najnowsze stery od razu i BIOS.
