Scorch92
Malware gameorplay.info - jak to usunąć?
-->>@Mayson24
Przez Panel Sterowania odinstaluj App Explorer.
Uruchom FRST a następnie (poprzez skrót klawiszowy CTRL + Y) otwórz notatnik systemowy. Wklej w nim poniższą zawartość:
ShellIconOverlayIdentifiers: [ OneDrive1] -> {BBACC218-34EA-4666-9D7A-C78F2274A524} =>  -> Brak pliku
ShellIconOverlayIdentifiers: [ OneDrive2] -> {5AB7172C-9C11-405C-8DD5-AF20F3606282} =>  -> Brak pliku
ShellIconOverlayIdentifiers: [ OneDrive3] -> {A78ED123-AB77-406B-9962-2A5D9D2F7F30} =>  -> Brak pliku
ShellIconOverlayIdentifiers: [ OneDrive4] -> {F241C880-6982-4CE5-8CF7-7085BA96DA5A} =>  -> Brak pliku
ShellIconOverlayIdentifiers: [ OneDrive5] -> {A0396A93-DC06-4AEF-BEE9-95FFCCAEF20E} =>  -> Brak pliku
ShellIconOverlayIdentifiers: [ OneDrive6] -> {9AA2F32D-362A-42D9-9328-24A483E2CCC3} =>  -> Brak pliku
ShellIconOverlayIdentifiers-x32: [ OneDrive1] -> {BBACC218-34EA-4666-9D7A-C78F2274A524} =>  -> Brak pliku
ShellIconOverlayIdentifiers-x32: [ OneDrive2] -> {5AB7172C-9C11-405C-8DD5-AF20F3606282} =>  -> Brak pliku
ShellIconOverlayIdentifiers-x32: [ OneDrive3] -> {A78ED123-AB77-406B-9962-2A5D9D2F7F30} =>  -> Brak pliku
ShellIconOverlayIdentifiers-x32: [ OneDrive4] -> {F241C880-6982-4CE5-8CF7-7085BA96DA5A} =>  -> Brak pliku
ShellIconOverlayIdentifiers-x32: [ OneDrive5] -> {A0396A93-DC06-4AEF-BEE9-95FFCCAEF20E} =>  -> Brak pliku
ShellIconOverlayIdentifiers-x32: [ OneDrive6] -> {9AA2F32D-362A-42D9-9328-24A483E2CCC3} =>  -> Brak pliku
ContextMenuHandlers4: [PowerISO] -> {967B2D40-8B7D-4127-9049-61EA0C2C6DCE} =>  -> Brak pliku
ContextMenuHandlers5: [igfxcui] -> {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} =>  -> Brak pliku
ContextMenuHandlers6: [PowerISO] -> {967B2D40-8B7D-4127-9049-61EA0C2C6DCE} =>  -> Brak pliku
Task: {0E93EE25-C4FE-4442-98C3-5AB5A7146510} - System32\Tasks\scofi => cmd.exe /c REG ADD HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run /f /v scofi /t REG_SZ /d "explorer.exe hxxp://exinariuminix.info" <==== UWAGA
Task: {1FF11584-D8CF-479C-8A8B-01626F2A98C3} - System32\Tasks\OneDrive Standalone Update Task v2 => C:\Users\scofi\AppData\Local\Microsoft\OneDrive\OneDriveStandaloneUpdater.exe
Task: {677B3080-FD47-43B5-9C21-3CE666A907EA} - System32\Tasks\App Explorer => C:\Users\scofi\AppData\Local\Host App Service\Engine\HostAppServiceUpdater.exe [2018-03-02] (SweetLabs, Inc) <==== UWAGA
HKU\S-1-5-21-1925906388-2480350806-3545138791-1001\...\Run: [scofi] => explorer.exe hxxp://exinariuminix.info <==== UWAGA
SearchScopes: HKU\S-1-5-21-1925906388-2480350806-3545138791-1001 -> DefaultScope {D6F2E91F-E3B0-4A58-A319-CE668A632D95} URL =
EmptyTemp:
Poprzez skrót klawiszowy CTRL + S zapisz zmiany w notatniku a następnie w FRST kliknij na Napraw. Na zakończenie naprawy FRST poprosi o restart systemu. Napisz później czy problem ustąpił.
Edytowane przez Gość
-->>@celny98
Otwórz Notatnik i wklej w nim:
Task: {6DFF2942-EB8D-4B99-A937-E6561EB80899} - System32\Tasks\zanet => cmd.exe /c REG ADD HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run /f /v zanet /t REG_SZ /d "explorer.exe hxxp://exinariuminix.info" <==== UWAGA
HKU\S-1-5-21-2736357013-985040161-66673251-1002\...\Run: [zanet] => explorer.exe hxxp://exinariuminix.info <==== UWAGA
RemoveDirectory: C:\82ace7d6-0197-474d-bf4b-a2043e72329b
HKLM Group Policy restriction on software: %systemroot%\system32\mrt.exe <==== UWAGA
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść w folderze C:\Users\zanet\Downloads
Uruchom FRST i kliknij przycisk Fix (NAPRAW).
Napisz, czy problem znikł?
Java 8 Update 144 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180144F0}) (Version: 8.0.1440.1 - Oracle Corporation)
Java 8 Update 151 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180151F0}) (Version: 8.0.1510.12 - Oracle Corporation)
Java 8 Update 161 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180161F0}) (Version: 8.0.1610.12 - Oracle Corporation)
Przy najbliższej aktualizacji Javy, wg strony https://www.fixitpc.pl/topic/5-dezynfekcja-kroki-finalizuj%C4%85ce-temat/#entry179769
dopilnuj, by nowa Java samoczynnie usunęła stare wersje Javy.
F.
Edytowane przez filutka78
Pomogło :D bardzo dziękuję za szybką odpowiedź. :D
Tez zlapalem to dziadostwo, prosze o pomoc, jestem zielony w tych sprawach jak cos bedzie nie tak z plikami to prosze pisac i wytlumaczyc co mam zrobic zeby bylo dobrze.
Addition
FRST.txt
-->>@Patrick4a
Task: {9E35FF30-98D0-46CE-A3D2-C5641362E813} - System32\Tasks\Patryk => cmd.exe /c REG ADD HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run /f /v Patryk /t REG_SZ /d "explorer.exe hxxp://exinariuminix.info" <==== UWAGA
StartRegedit:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
"Patryk"=-
EndRegedit:
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść w folderze F:\Download
F.
-->>@danys1200
Task: {41C18756-7B92-485E-8435-16013BD6417F} - \daniel -> Brak pliku <==== UWAGA
HKU\S-1-5-21-1776705200-258503478-3260956208-1001\...\Run: [daniel] => explorer.exe hxxp://exinariuminix.info <==== UWAGA
S4 nvvhci; \SystemRoot\System32\drivers\nvvhci.sys [X]
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść w folderze C:\Users\daniel\Downloads
F.
-->>@danys1200
F.
tak pomogło wielkie dzięki
czy jest jakiś sposób by się przed tym uchronić w przyszłości?
pozdrawiam
Tak, jest sposób, i to bardzo prosty: nie korzystać z zagranicznych stron z grami.
F.
-->>@casperklug
Task: {FE29F5FC-C155-418A-8860-A02AD06FEA10} - System32\Tasks\kacper => cmd.exe /c REG ADD HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run /f /v kacper /t REG_SZ /d "explorer.exe hxxp://exinariuminix.info" <==== UWAGA
StartRegedit:
"kacper"=-
EndRegedit:
S3 MSICDSetup; \??\E:\CDriver.sys [X]
2018-03-21 21:25 - 2014-08-21 14:31 - 015397208 ____N C:\Users\kacpe\Downloads\spyhunterS.exe
2018-03-21 21:23 - 2018-03-21 21:23 - 000000000 ____D C:\Program Files (x86)\Enigma Software Group
2018-03-21 21:22 - 2018-03-21 22:04 - 000000000 ____D C:\WINDOWS\4FC9DA9DF608454E8191D7EFFDCC5726.TMP
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść w folderze C:\Users\kacpe\Downloads
F.
-->>@arjjel
Task: {30DD5F3B-7BED-4A0F-9E9C-AB29539710A9} - System32\Tasks\Komputer => cmd.exe /c REG ADD HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run /f /v Komputer /t REG_SZ /d "explorer.exe hxxp://exinariuminix.info" <==== UWAGA
StartRegedit:
"Komputer"=-
EndRegedit:
S3 EagleX64; \??\C:\Windows\system32\drivers\EagleX64.sys [X]
S3 gdrv; \??\C:\Windows\gdrv.sys [X]
S3 MSICDSetup; \??\E:\CDriver64.sys [X]
S3 NTIOLib_1_0_C; \??\E:\NTIOLib_X64.sys [X]
S1 ZAM; \??\C:\Windows\System32\drivers\zam64.sys [X]
S1 ZAM_Guard; \??\C:\Windows\System32\drivers\zamguard64.sys [X]
HKU\S-1-5-21-474231750-4061604138-3688272429-1000\...\Policies\Explorer: []
HKLM\SOFTWARE\Policies\Microsoft\Windows Defender: Ograniczenia <==== UWAGA
HKU\S-1-5-21-474231750-4061604138-3688272429-1000\...\Run: [Akamai NetSession Interface] => "C:\Users\Komputer\AppData\Local\Akamai\netsession_win.exe"
RemoveDirectory: C:\ProgramData\boost_interprocess
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść w folderze C:\Users\Komputer\Downloads
F.
-->>@Denan06
1) Uruchom Google Chrome
> Naciśnij klawisze: lewy Alt+F i kliknij przycisk Ustawienia >
> Sekcja: Po uruchomieniu > wybierz: Otwórz konkretną stronę lub zestaw stron >
> Kliknij: Wybierz strony >
> Usuń: mail.ru,
2) Otwórz Notatnik i wklej w nim:
Task: {FCAF0E35-70AE-46C0-B129-E3F969F47E86} - System32\Tasks\Janek => cmd.exe /c REG ADD HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run /f /v Janek /t REG_SZ /d "explorer.exe hxxp://exinariuminix.info" <==== UWAGA
HKU\S-1-5-21-2968814812-2780733394-3510048762-1000\...\Run: [Janek] => explorer.exe hxxp://exinariuminix.info <==== UWAGA
SearchScopes: HKU\S-1-5-21-2968814812-2780733394-3510048762-1000 -> {FFEBBF0A-C22C-4172-89FF-45215A135AC7} URL = hxxp://go.mail.ru/distib/ep/?q={searchTerms}&fr=ntg&product_id=%7BCEAA8BDF-0E22-4BF7-8642-CBCBF8B018D7%7D&gp=811142
FF Plugin-x32: @microsoft.com/WLPG,version=16.4.3528.0331 -> C:\Program Files (x86)\Windows Live\Photo Gallery\NPWLPG.dll [brak pliku]
CHR HomePage: Default -> inline.go.mail.ru
CHR StartupUrls: Default -> "hxxp://www.google.com/","hxxps://www.google.pl/","hxxp://mail.ru/cnt/10445?gp=811138"
CHR DefaultSearchURL: Default -> hxxps://inline.go.mail.ru/search?inline_comp=dse&q={searchTerms}&fr=chxtn12.0.23
CHR DefaultSearchKeyword: Default -> inline.go.mail.ru
CHR DefaultSuggestURL: Default -> hxxp://suggests.go.mail.ru/chrome?q={searchTerms}
GroupPolicy: Ograniczenia <==== UWAGA
GroupPolicy\User: Ograniczenia <==== UWAGA
CHR HKLM-x32\...\Chrome\Extension: [bhjhnafpiilpffhglajcaepjbnbjemci] - hxxps://clients2.google.com/service/update2/crx
Task: {844BFFEA-CAC6-414C-8893-AA18BB5CAFBA} - \Microsoft\Windows\UNP\RunCampaignManager -> Brak pliku <==== UWAGA
Task: {C68CBB03-87D8-407B-A538-AD8DBAFA2181} - System32\Tasks\{30A1C717-0E4E-4C2A-A1D5-056B4F9E02DA} => C:\WINDOWS\system32\pcalua.exe -a D:\cmr2.0\CMR2.exe -d D:\cmr2.0
Powershell: wevtutil el | Foreach-Object {wevtutil cl "$_"}
CHR HKLM-x32\...\Chrome\Extension: [hcadgijmedbfgciegjomfpjcdchlhnif] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [ngdlmklkpclkhjopnhihdedhjgjmhlaa] - hxxps://clients2.google.com/service/update2/crx
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść na pulpicie.
3) Uruchom FRST.
W polu SEARCH (SZUKAJ) wklej:
*mail.ru*.*
kliknij na przycisk "Search Files (Szukaj Plików)".
Raport z tego będzie tam, gdzie jest FRST.
4) Uruchom FRST.
mail.ru
kliknij na przycisk "Search Registry" (Szukaj w Rejestrze).
5) Zrób nowe logi FRST.
przed skanem zaznacz: Additional.txt Shortcut.txt,
F.
-->>@Denan06
> Usuń: mail.ru, wpisz nowy adres strony głównej i kliknij przycisk OK.
RemoveDirectory: C:\Users\Janek\AppData\Local\Mail.Ru
StartRegedit:
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\IESearchPlugin.MailRuBHO]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\IESearchPlugin.MailRuBHO.1]
[HKEY_USERS\S-1-5-21-2968814812-2780733394-3510048762-1000\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store]
"C:\Users\Janek\AppData\Local\Mail.Ru\MailRuUpdater.exe"=-
EndRegedit:
EmptyTemp:
Powinno już być OK.
F.
-->>@Denan06
CHR HomePage: Default -> hxxp://mail.ru/cnt/10445?gp=811138
W dalszym ciągu strona "mail.ru" jest ustawiona jako domyślna strona główna.
Tego FRST nie zmieni, więc pogrzeb jeszcze w ustawieniach Chrome.
Poza tym:
C:\Users\Janek\Documents\Euro Truck Simulator 2\readme.rtf.lnk
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Movie Maker.lnk
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Photo Gallery.lnk
StartRegedit:
EndRegedit:
RemoveDirectory: C:\AdwCleaner\Quarantine\gxIX4a2dRE
RemoveDirectory: C:\AdwCleaner\Quarantine\exuieaoEiI
EmptyTemp:
F.
