VSS
Intel 10th cala seria
Więcej rdzeni od Intela to więcej prądu, czyli droższe chłodzenie, droższy zasilacz, wyższe temperatury, większa szansa padnięcia procka. Do tego sugerują, że TDP 125 wat przy 5.1-5.2 na wszystkich rdzeniach. Rocket Lake będzie wydajniejszy na 8 rdzeniach niż Comet Lake na 10, tak samo Zen 3.
Nie wydaje mi się, IPC musiałoby wzrosnąć o 30%. Raczej będzie na równi z 10/20
Lepsze chłodzenie?
Czy do intela czy do ryza trzeba kupić minimum jakaś fere.
Zasilacz?
To chyba raczej ze względu na kartę a nie procka :) Dobrej jakości +/- 600W do wszystkiego starczy - a czego byśmy w kompie nie mieli to 530W to total minimum co się kupuje :)
Źródło
Exclusive: Intel 10-Core CPU Thermal Focus
GamersNexus recently received information through a system integrator about the new Intel 10-core CPUs. We have verified the information as accurate.
Intel’s new 10-core CPU for the rumored Z490 platform, which has been talked about for at least a year now, has a renewed focus on thermal performance in order to maintain high clocks across more cores. The new 10-core CPU will be about 100mm^2 smaller than the previous 7900X 10-core chip, which makes sense, since it has fewer memory channels and less I/O. The 10-core CPU die will be lower to the substrate, bringing the IHS lower as well. It’s still going to be Intel’s solder solution from the 9900K, but with the die size increasing, the silicon getting closer to the substrate, and the IHS getting pulled in tighter to the CPU, the thermal solution should be overall improved versus the 9900K. The IHS has also been slightly redesigned. More die surface area to spread the heat across will help with the core count increase, as will bringing the silicon closer to the substrate and potentially reducing the silicone adhesive sealant.
The new die size is about 22x9mm, roughly measured, as opposed to 19x9mm for the 9900K and 22x14mm for the 7900X. As we understand it, the solution should be improved relative to the previous CPU.
The 10-core CPU will use socket 1200 motherboards. We have more information we are actively verifying and will likely release in our next HW News item, so check back for that
8x1,25=10 wiec ipc musi wzrosnac o 25 procent aby moc obliczeniowa sie zrownala
czysta teoria bo realnie rocket lake nawet z 10 procentowym wyzszym ipc oprawi comet lake tak samo jak 9700k robi to z ryzenem3700
tpd przy 5,1 bedzie znacznie wyzsze jak 125w,a to drozsze to mydlo powidlo. w zastosowaniach domowych najczesciej bedzie to ok 100 wat ,tak samo jak na coffy lake czy ryzenie
Lepsze chłodzenie?
do takich wiele rdzeniowych cpu to raczej minimum fortis...
Cały czas w przypadku 10th gen mowa tylko o i3/i5/i7/i9. Rozumiem że Celeronów oraz Pentium nie będzie w tej generacji?
Intel Pentium G6400 2/4 3.8 GHz 4 MB 65W TBD
Intel Pentium G6400T 2/4 3.2 GHz 4 MB 35W TBD
Intel Celeron G5900 2/2 3.2 GHz 2 MB 65W TBD
Intel Celeron G5900T 2/2 3.0 GHz 2 MB 35W TBD
Proszę bardzo.
Edytowane przez Bladzioch
Ja generację 10 przeczekam. Pewnie będą kosmiczne grzałki , a mój procek potrafi się zagotować na chłodzeniu AiO.
W sumie ciekawe czy uda się coś lekko zbić TDP dzięki nowej architekturze Willow Cove jak będzie wychodzić w 14nm w 11 generacji. :hmm:
jako sprzedawca intel bardzo imponuje .
sprzedał to samo 5 x cpu i mobo :lol2:
Proszę bardzo.
kto oprocz biura kupi dzisiaj 2/4? nawet jak to intel to moc obliczeniowa pod kreska
TDP może jeszcze wzrosnąć, to jest znacznie bardziej rozbudowany rdzeń od SkyLake i był projektowany z myślą o 10nm a nie 14. To że na siłę dają go do starszego procesu jest aktem desperacji i nie wiadomo co może z tego ostatecznie wyjść. Nie przypadkowo wg wstępnych informacji topowy procesor 11gen ma mieć "tylko" 8 rdzeni Edytowane przez blubaju
a co moze o ile 14 nm w co watpie to bedzie mniejszy zegar.
tylko po amd widac jak glupie 100 mhz robi cieplo
https://www.purepc.pl/procesory/test_procesorow_amd_ryzen_7_2700x_vs_intel_core_i7_8700k?page=0,44
te 18 procentowe ipc nie spawi ze proc odleci od dzisiejszych.
czekam na lga1700,tam 16 rdzeni zrobi robote
Edytowane przez michu20
O ja cię xD
Ta premiera jest przesuwana od stycznia.
Teraz w trakcie wirusa i tak popyt jest mniejszy na nowe rzeczy, więc będzie bardzo śmieszna generacja.
Dobra czas szukać jakiegoś używanego i7 6700 i czekać z nim do ddr5 xD
O ja cię xD
Jak chcesz to będę sprzedawał swojego 7700K przy premierze Ryzena 4000.
Czyli dostępność w ~czerwcu a 4 miechy później Ryzen 4000 :E :E
Procka potrzebuje na wczoraj ;), od stycznia czekam na 10th intela, bo mi gołe 4 rdzenie się mocno duszą, i potrzebuje czegoś chociaż 4/8.
to se zmień płytę i bierz 6 rdzeni-owca :P
To czekasz miesiącami na te same procesory (bo z 4/4 na 10/20 raczej się nie wybierasz) w dodatku z zawyżoną ceną na premierę i pewnie słabą dostępnością? :E
On czeka na spadek cen i7 6 i 7 gen.
To mu się z AMD chyba pomyliło
O ja cię xD
tia bedzie tak jak zawsze z cpu intela przy premierze... wiecej kupujacych jak procesorów i cena pojedzie w gore
W obecnych czasach wirusa, wolę oszczędzać kasę, niż wydawać na cały nowy sprzęt. ;)
:thumbup: Zgadłeś :) Czekam na 10th. gen. by ceny używanych 6-7gen spadły.
myslę ze 6500 z plyta z jakieś 500-550 zł by poszło (może jakbyś trafił na jelenia to i z 600-650) - dokładając ze 4 stówki kupujesz sobie R5 3600 i najtansze mobo na którym RAM można podkręcić i jestes happy :)
A z jakiego powodu by mialy spasc perocesory 3-4gen wstecz po wydaniu 10th?? Mysle ze o obnizkach mozesz zapomniec bo co mialo spas to spadlo a zaleta ost topowych ukladow na dana podstawke jest to ze nie trzeba zmieniac mobasa.
Dokladnie tak, zamiast inwestowac w 6700 to lepiej pojsc w R3600 i do tego szybkie ramy 3600Mhz bo nawet na tym 6700 te 2133Mhz to jest niestety slabo.
W sumie teraz i3 ma mieć 4c/8t więc nie wiadomo jak się rynek zachowa. Ceny mogą spaść ale na jakąś diametralną obniżkę jak przy ryzenach 1 generacji to bym nie liczył.
